It is currently Sun Sep 14, 2025 12:39 pm
PostPosted: Wed Sep 18, 2024 2:54 pm
When inlaying a mother of pearl logo do you use thin or medium superglue?
Formerly know as Mandodiddle.
PostPosted: Wed Sep 18, 2024 3:33 pm
I flood with thin then give it a shot of GluBoost.
PostPosted: Wed Sep 18, 2024 10:19 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I've used 24 Hour epoxy , thin CA, med CA and Glu-Boost Fill and Finish. I have also spot CA'ed the inlay, let it cure for a couple of hours then follow with epoxy. In all cases, I added black dye and rosewood sanding dust. 24 hr Epoxy seemed to be the easiest to file/ scrape and sand level. When adding dye to epoxy, mix dye into the resin first before mixing in the hardener.
Measure Twice,
Karl Borum
PostPosted: Thu Sep 19, 2024 7:37 pm
Thin if it's a fairly tight fit. Black medium if I'm putting it in black ebony if there are some gaps.
Sent from my SM-A526B using Tapatalk
These users thanked the author Pmaj7 for the post: Kbore (Fri Sep 20, 2024 11:57 am)
PostPosted: Fri Sep 20, 2024 5:59 pm
I most often use G2 epoxy mixed with ebony or rosewood dust. I always seem to have gaps. I make them a hair larger when inlaying into lighter woods so there is an even dark border around my inlays. I might be a little rough, but I'm slow. :)
PostPosted: Fri Sep 20, 2024 10:36 pm
I fit the inlay, rub appropriate dust into it with my finger and hit it with ultrathin Gluboost and accelerator.
Block sand and repeat if needed for any small gaps.
PostPosted: Sat Sep 21, 2024 8:18 am
Last Name: Colbert
City: Anacortes
I’m a CNC guy, so my inlays are a light press fit. Once you test fit them it’s almost impossible to get them back out. Wicking in thin CA is the only choice.
M
These users thanked the author Michaeldc for the post (total 2): Durero (Sun Sep 22, 2024 12:30 pm) • bcombs510 (Sat Sep 21, 2024 10:41 am)
